Forest Pack => Forest Pro (*) => Topic started by: lukx on January 26, 2018, 09:33:51 am
Title: why forest is squashing geometry?
Post by: lukx on January 26, 2018, 09:33:51 am
Why forestpack is squashing geometry?
Title: Re: why forest is squashing geometry?
Post by: Michal KarmazĂ­n on January 26, 2018, 03:34:24 pm
When using "scaled surface(s)" (like on your "Box002" object (207.064 %)) Forest will inherit this scale (and that's not always desirable). In these cases, we usually suggest applying the Reset XForm utility over that surface to reset its local coordinates & scale. This will require recreating Forest objects (or apply the Reset XForm modifier too, delete it and Update surfaces data) to get the right scale. Attaching screen-shots. Hope that helps.
Best regadrs,
Post by: amitgedia on January 28, 2018, 05:04:03 pm
this happened to me once too and i think Paul suggested the same thing of resetting the xform and it worked so i hope this helps you too mate...
Post by: FC1888 on January 29, 2018, 12:05:23 am
No geometry, should be scaled, unless you do so, in sub-object mode. If you just have to do it, you should  ALWAYS use reset xform, to correct the problems it will most definitely cause later down the line.
