Author Topic: Why is my grass floating?  (Read 5152 times)
UN7285
« on: October 11, 2018, 09:48:16 pm »
I cannot get this grass to go any lower in the Z than it currently is, but it will float up with the splines it's attached too.
What's up? Haven't ran into this yet and I can't seem to troubleshoot it.
Re: Why is my grass floating?
« Reply #1 on: October 12, 2018, 07:29:31 am »
Hello
If something is not as expected we recommend to try these troubleshooting steps:
  • Make sure surface normals are facing up
  • Check Pivot placement for scattered objects they should be at the bottom center of each object
  • Reset XForm for surface object
  • delete forest_templates layer and recreate ForestPack object again
If that does not help,- please share Your scene here or  use this form to contact us if You can't attach files publicly.
Also You can use WeTransfer if compressed file is bigger than 6MB and paste the link in message.
