Forest Pack => Forest Pro (*) => Topic started by: leo.surrealismo on June 08, 2023, 07:05:59 pm
Title: xref scene linked with a dummy
Post by: leo.surrealismo on June 08, 2023, 07:05:59 pm
hello!
I have a master scene with 4 linked Xref scenes aligned with dummyes each. The dummyes has a rotation o moving transformation.
When I merge this scenes, the forests looses its positions and they moves to arbitray positions.
Is it still a bug?
Title: Re: xref scene linked with a dummy
Post by: Michal Karmazín on June 09, 2023, 09:05:10 am
Can you please specify your setup more in detail? I‘m afraid, that there are several restrictions to any object referenced within XRef Scene(s) and as far as I know, there's currently no way how to bypass this limitation, therefore the recommendable workflow would be to use XRef Object(s) for used Custom Object(s) and insert FP objects in the "master scene".
Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
