Author Topic: FP 9.0.5b IVY - DR (distributed rendering) issues  (Read 84242 times)
BL_zoomvp
« on: July 08, 2024, 02:18:54 pm »
Hi there.
We are facing trouble rendering Forest Pack Ivy (9.0.5b) when DR is enabled.
The Master is rendering correct, but the slaves are missing the leaf-geometrie.
So we are get the classic bucket-errors.
For me it seems similar like the issue when camera-cliping is enabled in the "normal" FP.
We always disable the camera-feature when rendering DR.
Thank you in advance
Re: FP 9.0.5b IVY - DR (distributed rendering) issues
« Reply #1 on: July 08, 2024, 03:07:50 pm »
Thanks for reporting this, I've passed it to the development team for further investigation.
All the best,
« Reply #2 on: July 09, 2024, 10:58:19 am »
We are trying to replicate the problem here, but our tests using DR worked well (with and without a license installed).
What do you get exactly from the slave buckets ?
None is rendered ? or can you see only the branches without leaves ?
I would suggest to enable 'Transfer Missing Assets', in the Distributed Rendering settings.
BL_zoomvp
« Reply #3 on: July 09, 2024, 01:26:20 pm »
Hi.
long story short:
DR on Workstation with slaves = GOOD
DR-Job sent to Rendermanager (pulze) = BAD
I'm confused right now.
I checked it once again and, if I render DR on  my machine (even without trasfer missing assets), it works fine.
Only checked the default options as usual: "use local host" & "render region/test resolution warning". Btw we bearly never render DR on our workstations, instead we use Renermanager form pulze.
When sending a job to Rendermanager we get the discribed Bucket errors.
Yes you are right. Only the braches are visible.
I always wonder, how the DR jobs work with Pulze-Rendermanager. It seems that the issue has something to do with how these jobs are submitted ...
I'm pretty sure you are in contact with the pulze-team?
Maybe contacting them directly is the best option.
Thank you in advance.
« Reply #4 on: July 10, 2024, 09:20:13 am »
Yes, we're in contact with the pulze team. I just wrote to them.
BL_zoomvp
« Reply #5 on: July 16, 2024, 02:13:47 pm »
Thank you for collaborating.
The Pulze team replied that this misbehavior seems to happen only in our office.
We will use a workaround.
« Reply #6 on: July 16, 2024, 03:08:38 pm »
Same here.  We did some render tests, but we could not reproduce the problem.
