Author Topic: along spline  (Read 2779 times)
KD4391
along spline
« on: April 06, 2018, 01:57:43 AM »
hi guys, when i create a forest object on a surface and then do a custom edit, i cant find the option to distribute along the spline anymore?
FC1888
Re: along spline
« Reply #1 on: April 06, 2018, 03:30:09 AM »
Surely surfaces and splines are two separate things. If you create a forest scatter on a surface (polygons) and go to custom edit mode, you will get a warning
Switching to Custom Edit mode will disable Area/Distribution parameters. Are you sure?
But the part I find confusing is you say you cannot find the option to distribute along the spline any more... but you used a surface, not a spline???
If you have spline on a surface and the surface has a forest pro scatter, in custom edit mode. Just add another FP scatter for the spline. You can add many scatters to a single surface or spline and some can use custom edit and others not
KD4391
Re: along spline
« Reply #2 on: April 06, 2018, 04:19:19 AM »
my bad i think it was my wording so i went to the original documentation, its ALONG A PATH function - see attached
So i create items on a surface and do a custom edit and then distribute it along a path with this feature.  I cant find this anymore in the beta.
Re: along spline
« Reply #3 on: April 06, 2018, 08:33:06 AM »
