Forest Pack => Forest Pro (*) => Forest Pro beta => Topic started by: RealViz on September 09, 2022, 08:43:25 AM
I once had a suggestion for an improvement - unfortunately I can't find it now. It was about quickly changing the size of the brush. Instead of clicking on "Painter Options" put directly a box on "max size". Would it be possible to add this to version 8? I know you can use CTRL+SHIFT+LMB, but that is really tedious when changing from 20cm to 5000cm. Thanks
Thanks for your suggestion.
As general rule, we don't like to duplicate options, because the UI is already very heavy. But i will discuss it with our team.
