Author Topic: transforming reference objects in ForestSet - from layer  (Read 5188 times)
ritoo
« on: September 01, 2022, 04:17:32 PM »
Transforming reference objects (being a part of ForestSet -> from layer) won't  update forest in the viewport. It'd happen only after pressing update button. Transforming 'vanilla' reference objects is fine. Could it be fixed?
« Last Edit: September 01, 2022, 04:21:51 PM by ritoo »
Re: transforming reference objects in ForestSet - from layer
« Reply #1 on: September 02, 2022, 10:13:33 AM »
Unfortunately it's not possible, because ForestSet doesn't keep a reference to each object in the layer (it does when objects are manually added to the list).
Instead, it receives a notification when there are changes in the layer (for example, adding or removing objects), but not if an individual object is modified.
If that helps, in case you have multiple FP objects using layers, you can update everything clicking Display->Update All.
