Author Topic: Clusters now recognize multiple models with the same Color ID : how ?  (Read 696 times)
theedge
I saw this new feature in the beta :
Distribution->Diversity Map and Clusters now recognize multiple models with the same color ID
so I wanted to test it. But it doesn't seem to work, or maybe I'm doing it wrong :
 - I used 4 different objects for my test : 1:cone, 2:box, 3:torus, 4:teapot
 - Enabled Diversity>Clusters which generates clusters based on the 4 objects
 - Then I set the two first objects (1 and 2) with the same Color ID. It works : the two objects are used in the same clusters, but object N°4 (the teapot) disappears completely
 - If I set objects 3 and 4 to share the same Color ID both disappear completely.
Here is a little screengrab of what happens : http://c2n.me/3rVb404
I attached the scene to this post.
Re: Clusters now recognize multiple models with the same Color ID : how ?
« Reply #1 on: December 21, 2015, 08:54:34 AM »
Yes, you are right, there is something wrong. It works only if the duplicated ID is the last element of the list.
We'll check it. Thanks for reporting the problem.
