Author Topic: DR in VRay  (Read 626 times)
OI3404
DR in VRay
« on: June 28, 2017, 01:51:32 PM »
I had installed Vray 3.60.01 and Forest Pack Pro  534b.
I have two workstations (Win7) and in DR they are ok.
On my render nodes (Win XP) the Forest objects don’t show up.  I think it was a problem of paths and then i modify the 3dsmax.ini on render nodes. A no go… after some test, I verify that VRay DR modifies the render nodes 3dsmax.ini and the paths of Forest pack are removed…
I need help… In previous versions, all work
Thanks in advan
Re: DR in VRay
« Reply #1 on: June 28, 2017, 04:06:55 PM »
Hi, unfortunately Windows XP is not longer supported in FP 5.3.4 and above.
That doesn't mean this problem is caused by this limitation, but we suggest to not use latest releases with Windows XP, because unexpected behaviour would appear.
Regarding 3dsmax.ini, Forest installation doesn't modify it. Not sure if V-Ray does it...
OI3404
Re: DR in VRay
« Reply #2 on: June 28, 2017, 06:07:06 PM »
Thx Carlos,
I revert the render nodes to VRay 3.50.04 and Forest Pack to 5.3.0 maintaining the workstations with VRay 3.60.01 and Forest 5.4.0 and for now, work....!!!??? :) I have to upgrade the render nodes to win7 soon...
Thx for the help... best regards
Re: DR in VRay
« Reply #3 on: June 29, 2017, 08:55:17 AM »
Hi, i think that combination should work temporary. There are not big changes between FP 5.3.0 and 5.4.0 and scenes should be compatible.
The only problem would be the compatibility between V-Ray 3.50.04 and 3.60.01. ChaosGroup can give you more information about that.
