Forest Pack => Forest Pro (*) => Forest Pro beta => Topic started by: Bobby Parker on May 30, 2024, 07:21:23 pm
Title: Forest Listener
Post by: Bobby Parker on May 30, 2024, 07:21:23 pm
I can't see the full Forest name. I can only see "Forest" and I can't extend the column.
Title: Re: Forest Listener
Post by: Michal KarmazĂ­n on May 31, 2024, 08:50:11 am
Hi Bobby,
You can either resize the Forest Lister (https://docs.itoosoft.com/forestpack/forest-lister) window to display the full Forest object name or remove some column(s) (https://docs.itoosoft.com/forestpack/forest-lister#to-remove-columns) via the Lister Options window. I hope this helps.
Post by: CharlyRT on June 01, 2024, 09:26:50 pm
hi
in the lister from the beta if i tried to select multiple elements holding shift most of the time it just select one or two, in previous versions i could select all of them
sometimes if i select all i cannot select just one, its a little buggy
I attach the behavior in previous versions and beta
