Author Topic: Forestpack 7 Beta 4 Object dissapear on final render  (Read 175 times)
RTstudio
« on: February 15, 2021, 07:26:59 PM »
Hi there, Im using the last update from 7th Beta and Vray 5 hotfix2, im trying to use state sets with different camera setups: Fisheye, Panorama & Perspective, when I render all the cameras at once using the states, the forest object dissapears, also if i render manually without the state set it dissapears, but if I use the IPR, the objects render normally, i´ve tested in other simple scene and the scene renders ok.
« Last Edit: February 15, 2021, 08:23:22 PM by RTstudio »
    • iToo
Re: Forestpack 7 Beta 4 Object dissapear on final render
« Reply #1 on: February 17, 2021, 07:55:12 AM »
Hi.
It would help us to investigate the issue if You could send simplified scene to us.
RTstudio
« Reply #2 on: February 17, 2021, 05:14:35 PM »
Thanks for replying, i´ve tested it with version 6 and its working ok, also i´ve simplify the scene with no objects nor materials, only vraydome and its still there, i've tested it with bucket & progressive and  again its still there, only on IPR renders ok
The file its for max 2021, let me know if you need it for an older version, thanks.
    • iToo
« Reply #3 on: February 17, 2021, 05:31:49 PM »
21 is fine. We will check it tomorrow. Thank You.
We will check why this happens but for new it would make sense to just disable "Limit to visibility" feature.
« Last Edit: February 17, 2021, 05:47:19 PM by Rokas »
    • iToo
« Reply #4 on: February 17, 2021, 07:03:09 PM »
interesting. thank You for the info
