Author Topic: Noticeable line in the generation pattern  (Read 34420 times)
Arrow3d
« on: June 28, 2024, 03:56:30 pm »
I think it mush be something to do with the interaction between the wall and the fence models. I've tried combining the 2 into one object but it gets similar results
Re: Noticeable line in the generation pattern
« Reply #1 on: June 28, 2024, 04:28:55 pm »
Trying to figure out what is happening in your scene just from the image is a bit challenging. If possible, please do not hesitate to send us your scene (preferably simplified and including only the problematic object(s)). Thank you in advance.
Arrow3d
« Reply #2 on: June 28, 2024, 04:48:12 pm »
Sure no worries, sent
« Reply #3 on: July 01, 2024, 10:40:28 am »
Hi Alexander,
Thank you for providing the scene. There seems to be an issue with the topology of the surface "Shape001", likely related to the Chamfer modifier settings. Disabling the "Filter By > Min. Angle" option appears to resolve the issue. Optionally, you can also fix it by adding some edge loop(s), for example, using the Slice modifier in the Refine Mesh mode. I hope this helps.
