Author Topic: FP7 / VRAY 5.03 - FP obejct changes to gray after scene save while IPR is on  (Read 274 times)
GF1991
Hello again,
ok so if i render with IPR turned on and running and perform a scene save then afgter the scene save has ended, the FP objects renders gray.
I have to close max and restart it. it doesnt help to just stop IPR and run it again.
Happens on the grass object in the scene i have already provided in my previous post with crashing scene here:
https://forum.itoosoft.com/forest-pro-beta/fp-7-vray-5-hotfix-2-fp-object-crashing-when-using-ipr-and-stopping-render/
so if you stiull have the scene you might as well test it :)
Cheers
M
    • iToo
yes, can reproduce not only in Your scene. Thanks.
Note:
simpler short time "fix"- render it with production renderer, then start IPR again.
Also refreshing seems to work in our (simpler scene) tests.
In Your scene also- I could reproduce few times, but today, it refreshes with refresh button.
IPR has many other problems. With IPR- feel free to experiment, but don't be surprised when it breaks.
As there is a saying: "Your mileage may vary".
« Last Edit: March 01, 2021, 01:33:28 PM by Rokas »
GF1991
thank you Rokas!
GF1991
IPR is what it is. Sometimes it breaks so bad that i have to restart computer. Regardless the scene type.
