Hard to explain, but just try this:
Scatter objects as usual in FP 6 on UV surface. Then got to Item level (parametric settings such as distribution/scale/etc. are then of course lost) and you can now individually select and edit the instances.
Load the same scene with FP 7, and selection of the individual items is broken (somehow seems to select just the original instance)?!
