Author Topic: FP7 library  (Read 202 times)
RealViz
FP7 library
« on: November 16, 2020, 01:13:17 PM »
Thank you for the new library. It's great, fast for loading thumbnails (+ cache), creating new ones! Thanks
However, I have an idea for improvement. Would it be possible to specify a default "3D Objects creation" for each item? Some we use as vrmesh and some as xref. We often get confused when importing. Using pure xref is not the solution. The scenes then load for a long time.
    • iToo
Re: FP7 library
« Reply #1 on: November 16, 2020, 01:27:22 PM »
I am sorry, I did not understand, especially VRMESH part.
RealViz
Re: FP7 library
« Reply #2 on: November 16, 2020, 02:29:36 PM »
When using an object from the library that is in VRproxy (VRmesh), we use "Merge into scene". Because it inserts a proxy object cleanly. Good for people, furniture, etc. We use an xref object for vegetation, because ForestColor works properly.
It would be possible for the "3D Objects Creation" option (according to the attached image) to be defined for each library item.
