Author Topic: Max crashes when rendering after upgrading to the 9 beta  (Read 34562 times)
OU9561
« on: May 29, 2024, 03:40:03 am »
Here's the crash info:
Date/Time: 2024-05-28 22:36:51 -03:00
Application: 3dsmax.exe
Error: Integer divide-by-zero - code c0000094 (first/second chance not available)
Crashed Module Name: ForestPackPro.dlo
Exception Address: 0x00007ff9191f3d53
Exception Code: c0000094
Exception Flags: 0
Exception Parameters:
I'm ataching the error dump in case it's useful too.
Re: Max crashes when rendering after upgrading to the 9 beta
« Reply #1 on: May 29, 2024, 08:42:04 am »
Thanks for the minidump.
I could identify where is the problem. It will be fixed on next update.
OU9561
« Reply #2 on: May 29, 2024, 06:44:28 pm »
Thank you... any pointers on something I can do on my end in the meantime? or just go back to the stable version? (was really looking forward to play with Forestivy...)
« Reply #3 on: May 30, 2024, 08:31:21 am »
Crash happens only rendering Forest on 'Surface UV' mode. It doesn't affect to XY mode or ForestIvy.
You can bypass the crash setting Display->Render->Simplification Level = 1 (default value is 0).
Anyway, please note that once fixed the bug (for next beta update), you must revert this value to zero, to get the right distribution.
OU9561
« Reply #4 on: May 30, 2024, 02:02:38 pm »
Thank you! I was using UV mode because I have stacked surfaces on the same object and I never quite figured out how to make that work in XY mode...
