Author Topic: Nested Forests  (Read 3587 times)
    • iToo
Nested Forests
« on: February 18, 2018, 10:14:33 AM »
Nested forests crash max (2016) vray 3,6
Re: Nested Forests
« Reply #1 on: February 20, 2018, 11:08:40 AM »
Please, try assigning some material to the inner FP. That solves the crash.
In FP6, the viewport materials ("FP ColorID") are not generated in render. In this case, Forest was creating a multi-sub without any material, crashing V-Ray.
I've added a fix in the code to handle the no-materials case.
    • iToo
Re: Nested Forests
« Reply #2 on: February 20, 2018, 11:20:29 AM »
Thank You.
no crash, but master FP still empty without geometry:
Re: Nested Forests
« Reply #3 on: February 20, 2018, 12:34:56 PM »
Strange, i cannot reproduce that issue. I did the following:
1) Dropped a VRayMtl from the Material Editor to "Cylinder001" (grass blade).
2) Removed the material assigned in Forest002->Geometry->Material  (if not the materials are not propagated from the inner correctly).
I'm using FP 6.0.1, Max 2016 and V-Ray 3.60.04
    • iToo
Re: Nested Forests
« Reply #4 on: February 20, 2018, 08:44:04 PM »
Attached scene wont render correctly: checked in two PCS.
nor max2016 nor 2018.
Re: Nested Forests
« Reply #5 on: February 21, 2018, 10:38:55 AM »
Ok, you assigned a VRayMtl to Forest001 (inner object), but it's not used by the outer FP because there is a material assigned in Forest001->Geometry->Material, and "Consolidate Materials" is enabled.
Specifically it has assigned the automaterial of Forest002, which is composed only by the viewport materials (FP Color ID...), because the grass blade (Cylinder001) had not any material assigned.
In FP5, it renders because the viewport materials are created on render, but in FP6 not. We had to change this behaviour, to fix an error with the interactive renders.
Please, try this:
- in Forest001->Geometry, click Material->Clear, to remove any material which is assigned.
- Repeat the process in Forest002.
- Assign some VRayMtl to Cylinder001.
Doing this, the material is propagated from the grass blade to all FP objects correctly.
    • iToo
Re: Nested Forests
« Reply #6 on: February 21, 2018, 01:35:43 PM »
Thank You for thorough explanation. Good to understand.
I know some users hates popups, but this case deserve an pop up too:
"Some of Your forestpack objects has no material assigned.
It may not render as expected."
Re: Nested Forests
« Reply #7 on: February 22, 2018, 10:33:15 AM »
Well, really that will not be necessary, because with the changes i did, now it renders correctly even without a material.
These changes will be included in the next beta.
    • iToo
Re: Nested Forests
« Reply #8 on: February 22, 2018, 10:59:34 AM »
fantastic !
