Forest Pack => Forest Pro (*) => Forest Pro beta => Topic started by: Arrow3d on June 28, 2024, 03:56:30 pm
I think it mush be something to do with the interaction between the wall and the fence models. I've tried combining the 2 into one object but it gets similar results
Trying to figure out what is happening in your scene just from the image is a bit challenging. If possible, please do not hesitate to send us (https://forum.itoosoft.com/faq/how-to-send-a-file-to-itoo-software/) your scene (preferably simplified and including only the problematic object(s)). Thank you in advance.
Sure no worries, sent
Hi Alexander,
Thank you for providing the scene. There seems to be an issue with the topology of the surface "Shape001", likely related to the Chamfer modifier settings. Disabling the "Filter By > Min. Angle" option appears to resolve the issue. Optionally, you can also fix it by adding some edge loop(s), for example, using the Slice modifier in the Refine Mesh mode. I hope this helps.
