Author Topic: Path distribution not randomizing properly on FP6 beta  (Read 2313 times)
TQ2762
« on: March 09, 2018, 03:18:36 PM »
Hello everyone.
I am testing the new beta version and overall is pretty good, but i am having problems on using path distribution.
On this version, path distribution is located on distribution parameter and not on tree editor as before, so i am using path distribution to randomize cars on a spline, but it seems it is following a pattern instead of just randomizing. I expected a lot of randomization but is not happening.
I have attached image to make it a bit clear.
Does someone know how to solve the problem? I have just downloaded beta 2 and the issue is still there.
I really appreciate it.
Re: Path distribution not randomizing properly on FP6 beta
« Reply #1 on: March 10, 2018, 09:30:22 AM »
Hi, you are right, the random distribution is the same for each sub-spline.
We were not aware of this issue. It will be fixed for next update.
Until then, you can do this:
1) Create the Path Distribution normally.
2) Go to the Items Editor and switch to Custom Edit mode.
3) From the sub-object mode, select all items.
4) Click the "Randomize" button (within the "Properties" group).
TQ2762
« Reply #2 on: March 12, 2018, 03:20:24 PM »
Thank you for the reply.
That helps for now, thank you very much!
