Author Topic: All scattered facing one object how?  (Read 45776 times)
xinulo
« on: January 23, 2022, 01:19:54 pm »
Hi Guys,
What is the easier way to scatter many objects and then have them all facing one object.
Re: All scattered facing one object how?
« Reply #1 on: January 23, 2022, 02:37:01 pm »
ForestPack with Look-At Effect should do the job.
xinulo
« Reply #2 on: January 23, 2022, 05:45:09 pm »
Great! Thank You Dragan ! :)
Unfortunately my effects library is empty hmm..I need to figure that out with support
« Reply #3 on: January 23, 2022, 06:11:31 pm »
What is your current version of the ForestPack?
The Effect Library directory should be at:
C:\Users\#####\AppData\Local\Itoo Software\Forest Pack Pro\effects
note:
You need to add effect first and then assign/select from the Default library.
xinulo
« Reply #4 on: January 23, 2022, 06:54:28 pm »
Hi Dragan,
Thanks!
Yes that is what I did ..my path is someway different..I remember when I installed it I had issues and spent week with support about not able to load some libraries..as my user name used cirilic..and gave up ..start using it as it it as I had to reinstall windows..
so Here is prinscreens..effects are there in a folder but not showing:(
xinulo
« Reply #5 on: January 23, 2022, 06:56:56 pm »
here us the files
« Reply #6 on: January 23, 2022, 07:12:27 pm »
Try to create a Folder/files manually to C:\Users\#####\AppData\Local\Itoo Software\Forest Pack Pro\effects
Second:
If you know where your effect files are located you can import them manually.
« Last Edit: January 23, 2022, 07:15:45 pm by Dragan »
xinulo
« Reply #7 on: January 23, 2022, 07:27:53 pm »
GReat Dragon thanks a lot !
I managed manually as you have  showed me ! :)
« Reply #8 on: January 23, 2022, 07:38:15 pm »
Great! Glad to help.
P.S. It is Dragan (although Dragon is not bad  ;) ) and Ћирилица is my native too  ;)
« Last Edit: January 23, 2022, 09:49:55 pm by Dragan »
xinulo
« Reply #9 on: January 23, 2022, 09:00:18 pm »
 :) Sorry mispelled  it DD Dragon_Dragan:)
