Author Topic: Missing effects in Forest 8 effects library  (Read 42813 times)
gitano_anton
« on: December 02, 2022, 08:58:14 am »
Hello.
I´ve seen the video tut about bend rug strands next to exclude splines but I can´t find the "bend by exclude area" in the effects list, as seen in video.
It´s missing in Forest 8?
Thanks...
Re: Missing effects in Forest 8 effects library
« Reply #1 on: December 02, 2022, 11:07:09 am »
The "Bend by exclude area" effect you should find under the Transform category (it should be listed as a second effect just after the "Face Downhill" one). I hope that helps.
« Reply #2 on: December 02, 2022, 11:32:45 am »
If you cannot find it, please run Update Manager to install new Effects package.
These effects were uploaded some days after the Forest 8 release.
gitano_anton
« Reply #3 on: December 02, 2022, 11:37:09 am »
Thanks for your answer Michal...
Bend by exclude are doesn´t appear where it´s suppossed to be.
I´ve updated forest with Update Manager yesterday
It seems to be a problem with 8.06 version. In Forest 8.05 the effect is in the list
« Last Edit: December 02, 2022, 12:59:14 pm by gitano_anton »
« Reply #4 on: December 02, 2022, 01:41:09 pm »
Well, it has been reorganized in the last update and the “Lean out (Exclude)” effect should give you the same result. Anyway, please the “Bend by exclude area” effect attached. I hope that helps.
