Author Topic: HD Plants Script to set shaders to Vray  (Read 43850 times)
MN3180
« on: December 10, 2012, 11:01:07 pm »
My company has purchased HD Plants 1 and 2, I have installed the catalogue to the library, it all works fine and as expected. But I have a problem, now I have a couple of hundred files containing plants with MR shaders on as default, I need to update these to vray shaders, and update the bitmap paths to my local file structure. Is there a simple/scripted way to do this? Opening hundreds of files and altering and re-saving is very unappealing.
yuv
  • iToo Software - CEO
    • Itoo Software
Re: HD Plants Script to set shaders to Vray
« Reply #1 on: December 10, 2012, 11:54:03 pm »
If you use the HQ Plants trought Forest Pack and the HQ Catalog add-on, the vray materials are applied automatically. Please see this tutorial for instalation steps:
http://www.itoosoft.com/forestpack/tutorials/tutorial_library_addon.php
Daniel Quintero
Itoo Software
www.itoosoft.com
daniel@itoosoft.com
TL1895
« Reply #2 on: May 29, 2013, 11:42:08 pm »
Same problem here, but add the following;
When using some of HQ Grass in Vray via Forest, the grass file being referenced by default has a MR material applied.
I think that "Bedstraw" are the specific models I am mentioning in this case, although it may happen elsewhere that I have only yet to notice.
« Reply #3 on: May 30, 2013, 09:39:49 am »
You are right, the Bedstraw VRay model have a wrong material assigned.
3D Mentor should fix it, but there is an easy workaround:
1) Open the file models-vray\vray-models-bedstraw-01.max.
2) Select the VRay material from the material editor, and apply it to the scene's objects.
3) Save the scene.
Doing this, it will work fine from HQ Catalog.
TL1895
« Reply #4 on: June 03, 2013, 02:08:49 pm »
You are also right, it is an easy fix, but I worry how many more I will encounter.
Not so quick if you have to open/check/re-save all the models...
