Author Topic: Error creating a 3D object in the library  (Read 56529 times)
KF3274
« on: November 10, 2013, 07:22:46 pm »
I have the following problem in the "Library Browser"
When I create a 3d object dir looking for the window object nalla Max file after open
Message I get the following error:
Warning
" Is is not possible to do this operation if a Max obiect is being created.
Please, open the Library Browser from the Max Modify panel and try again."
I get the same error even when I run the procedure to import the object ..
I try to create the objects that are in a folder in the browser specified in the Preferences:
Varie                   C:\Documents and Settings\Administrator\My Documents\Forest Pack\Varie\libs
the folder name is "Am_58".
The version of the forest is "4.14"
"HQ Catalog is the" Version 130 "in
C: \ Documents and Settings \ Administrator \ My Documents \ Forest Pack "
here are three libraries:
"Varie"
"User's Library"
"HQ Plants Catalog"
regedit
chiave
LibraryDir
queste dir
Forest Library  C:\Program Files (x86)\Itoo Software\Forest Pack Pro\lib
HQ catalog       C:\Documents and Settings\Administrator\My Documents\Forest Pack\HQ Plants Catalog\lib
Use Max 2009 a 64 Bit
in "hq catalog" is installed "hp_plant_1"
and "hq_grass_1" I always find it hard to install.
Re: Error creating a 3D object in the library
« Reply #1 on: November 11, 2013, 08:41:48 am »
There are certain Max restrictions to create an item when a Forest object is being created. For this reason, you will find two "Library"buttons: one on the Creation panel and other at Modify. Just open the library and create your items from the "Modify" tab.
KF3274
« Reply #2 on: November 11, 2013, 04:42:32 pm »
Thank you.
I lost five hours to find this step! :)
