Author Topic: HQ Plants Viola's don't work for me (after installing FPP 4)  (Read 38044 times)
TM3598
« on: February 22, 2013, 08:29:10 pm »
I've checked the paths in the "External File" section of Customisation and the paths are correct.
I have Trees 3 and Flowers 2 and all of these items work fine EXCEPT for Viola !!
And it just so happens that these are the plants I want tin use in my Flower Box.....
Re: HQ Plants Viola's don't work for me (after installing FPP 4)
« Reply #1 on: February 22, 2013, 11:19:40 pm »
In the original files of 3D Mentor, there was a mistake in the Max file for the Viola mode: HD_Vilola_01.max instead HD_Viola_01.max, so we wrote our catalog to use exactly this name.
Please, would you check what is the file name in your copy of HD Flowers 2 ?
Anyway, you also can use the models manually (without the catalog). Just merge the model in the scene, and assign to to Geometry->Custom Object.
mentor
« Reply #2 on: February 23, 2013, 03:45:38 am »
I'll fix it in the next update. Thank you for feedback.
TM3598
« Reply #3 on: February 23, 2013, 10:19:42 am »
What is in my copy is
HD_Vilola_01.max
But if I change it to HD_Viola_01.max, it still doesn't work.
Anyway, as you say, merge in ans assign to Geometry.
« Reply #4 on: February 23, 2013, 10:35:49 am »
The Viola models seems to work fine here, using the catalog, both for VRay and Mental Ray.
What error did you get exactly ? and what render engine do you use ?
