Toggle navigation
Login
Register
Other boards
Third party products
Problem with mesh view
« previous
next »
Print
Pages: [
1
Author
Topic: Problem with mesh view (Read 51744 times)
Lintang
Newbie
on:
June 10, 2012, 01:19:41 pm »
hello,
i use 3dsmax 2012 and HQ Catalog 1.0
when I use the HQ plants by selecting the library, I found a problem when the mesh view, the tree is gone (nothing), and only letter ' F ' in the floor, and, when i render, i found error again, help me!
Logged
Administrator
Hero Member
Re: Problem with mesh view
Reply #1 on:
June 10, 2012, 01:26:45 pm »
Please, click "General->Forest Stats", to open the information window, and see what it is the problem exactly.
Logged
Lintang
Newbie
Reply #2 on:
June 10, 2012, 03:50:18 pm »
the problem is
"Maximum number of faces exceeded
fix : adjust "Display" parameters"
i'm sory what that mean ?
Logged
Administrator
Hero Member
Reply #3 on:
June 10, 2012, 04:19:09 pm »
Probably you are using the scanline renderer. This render engine is very limited to handle high-poly objects (as the HQ Plant models), because it creates a single mesh with all the plants. You should use Mental Ray or VRay.
In this is not the case, please check if Display->Render Mode is set to "Automatic".
Logged
Print
Pages: [
1
« previous
next »
Other boards
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
