Author Topic: Problem with mesh view  (Read 51729 times)
Lintang
« on: June 10, 2012, 01:19:41 pm »
hello,
i use 3dsmax 2012 and HQ Catalog 1.0
when I use the HQ plants by selecting the library, I found a problem when the mesh view, the tree is gone (nothing), and only letter ' F ' in the floor, and, when i render, i found error again, help me!
Re: Problem with mesh view
« Reply #1 on: June 10, 2012, 01:26:45 pm »
Please, click "General->Forest Stats", to open the information window, and see what it is the problem exactly.
Lintang
« Reply #2 on: June 10, 2012, 03:50:18 pm »
the problem is
"Maximum number of faces exceeded
fix : adjust "Display" parameters"
i'm sory what that mean ?
« Reply #3 on: June 10, 2012, 04:19:09 pm »
Probably you are using the scanline renderer. This render engine is very limited to handle high-poly objects (as the HQ Plant models), because it creates a single mesh with all the plants.  You should use Mental Ray or VRay.
In this is not the case, please check if Display->Render Mode is set to "Automatic".
