Author Topic: I cannot install hq catalog on Forest pack 4.3.2b  (Read 63680 times)
Alessandro Guida
« on: December 16, 2014, 08:33:04 pm »
Due I am using beta version maybe i cannot access to the hq catalog by geometry roll out...
any sugestion? i need some pebbles
hq is last version
Re: I cannot install hq catalog on Forest pack 4.3.2b
« Reply #1 on: December 17, 2014, 09:47:23 am »
Hi Alessandro,
Would you please specify your troubles with the Library Browser more in detail (ideally upload some screenshots too)? Actually, we did some additional testing here and it's all working fine. Thanks in advance.
Also feel free to check this video tutorial showing the HQ Catalog installation and use of the Library Browser integrated in Forest Pack.
Once the add-on installed, please double click on any item in the library you have purchased and when HQPlants Libraries window pops up, map the path to your files by pressing Select installation Path button. You should select the corresponding folder where you unpacked your HQ models (not the maps folder).
Kind regards,
Alessandro Guida
« Reply #2 on: February 08, 2015, 11:52:51 pm »
when I try To access the library going to the Geometry rollout, select or add a geometry item and click on Properties>Library to open the Library Browser. nothing happens
« Reply #3 on: February 09, 2015, 10:51:57 am »
Hi Alessandro,
Sound like the Library Browser window opens out of your actual screen. Please try to reset the Library Browser window position by deleting following system registry key:
HKEY_CURRENT_USER\Software\Itoo Software\Forest Pack Pro\CatalogWnd
This should fix your troubles. If the issue persist, please let us know. Thanks in advance.
Kind regards,
Alessandro Guida
« Reply #4 on: February 10, 2015, 05:37:48 pm »
solved thank you.
