Author Topic: Suggestions for RailClone Tips&Tricks tutorials  (Read 123345 times)
Wilbert
Re: Suggestions for RailClone Tips&Tricks tutorials
« Reply #15 on: July 23, 2014, 01:27:06 PM »
A tutorial for creating a stair with landings and railing for an oil tank would be great. (I've been trying to do this but I never got it exactly right)
« Reply #16 on: July 23, 2014, 02:35:19 PM »
Thanks for the interesting suggestions.
I've added them to our wish lists. Keep them coming!
Paul.
Rtst
« Reply #17 on: September 02, 2014, 01:33:56 AM »
It would be great to have an Alucobond Facade Cladding Preset!
http://www.stylepark.com/en/3a-composites/alucobond-silbermetallic-500
satoer
« Reply #18 on: December 11, 2014, 10:34:39 AM »
I really would like an tutorial specifically targeted at the Arithmetic Expression Operator. This seems to be very powerful, and since the user bought this plugin for its parametric modelling abilities, mastering this part of the plugin probably can enhance the parametric possibilities of Railclone significantly.
But first, the help-box inside the editor needs to be way more helpful. Now it’s really too basic to get an idea what an variable does. For example, the “XSplineCoords” This is used by the bridge tutorial to size the pillars to the ground. The help about this variable is: “Position over X Spline on local coordinates (vector)
But how did I supposed to know that XSplineCoords.z gives me just the Z - value? It would really help if this help box gives some basic examples and a list of optional parameters we can use.
« Last Edit: December 11, 2014, 10:37:59 AM by satoer »
ISG_User
« Reply #19 on: February 18, 2015, 04:09:20 PM »
Scaffolding, so it can be drawn using horizontal and vertical spline.  Set distance between decks.  diagonal bars are created over a set distance. Monoflex too, the occasional logo.
Wade
« Reply #20 on: March 11, 2015, 04:55:04 AM »
Traffic. Not sure if its possible with RailClone for Forest. It doesn't have to move.
« Reply #21 on: March 11, 2015, 08:27:56 AM »
There is a recent thread about this kind of application. You can find it here.
IT1371
« Reply #22 on: March 13, 2015, 07:32:27 AM »
Is there a possibility to add a UVW map modifier inside the Railclone object?
To avoid things like this?
« Reply #23 on: March 13, 2015, 08:41:04 AM »
It already exists, as Segment->Mapping. Unlike standard mapping, it generates a seamlessy tiled along the RailClone object.
IT1371
« Reply #24 on: April 07, 2015, 08:53:22 AM »
I suggest adding a little button to select the participating spline in the Railclone object, instead of selecting it manually in the viewport.
« Reply #25 on: April 07, 2015, 11:27:38 AM »
You can use rightclick and use top left quad while RC is selected to select spline
suppenhuhn
« Reply #26 on: April 21, 2015, 05:33:22 PM »
Will there be a tutorial for the Window example from the Railclone 2.4 feature tour video? Would be awesome!
iToo has probably the best support & community i know !!
I'm using it with Max 2019 & Vray 6
« Reply #27 on: April 22, 2015, 12:45:44 PM »
I think that could be arranged ;)
suppenhuhn
« Reply #28 on: April 25, 2015, 02:35:05 PM »
YEEEEEHAAAAAW
IT1371
« Reply #29 on: May 26, 2015, 06:36:56 PM »
Is there a possibility add to Export the Reverse, Flip A and Flip B parameters? for the Linear 1S item?
That could be great to faster set up some of my stuff :)
