Author Topic: Railclone Library  (Read 4225 times)
Bobby Parker
Railclone Library
« on: June 13, 2017, 03:11:39 PM »
I updated RailClone (update manager) and now my RailClone Library is gone.
Re: Railclone Library
« Reply #1 on: June 13, 2017, 03:18:45 PM »
In RC3, Library, Materials and Maps are located under:
C:\Users\<your username>\AppData\Local\Itoo Software\RailClone Pro
Can you please double check from the Library Browser's interface under File - Preferences ... - System Macros the librootpath value? Thanks in advance.
Bobby Parker
« Reply #2 on: June 13, 2017, 03:56:25 PM »
My Itoo Software folder only has an Update Manager folder.
Bobby Parker
« Reply #3 on: June 13, 2017, 03:56:54 PM »
And here is my preferences
« Reply #4 on: June 13, 2017, 04:19:07 PM »
Libraries, Maps and Macros have been removed from the installer and are now available to download from the Update Manager. Please open the Update Manager, login with your user-name and password included with your license(s) and update all packages.
Bobby Parker
« Reply #5 on: June 13, 2017, 04:35:21 PM »
All the packages are up to date.
Bobby Parker
« Reply #6 on: June 13, 2017, 04:51:27 PM »
It seems like uninstalling and reinstalling the packages work but is surely a pain.
« Reply #7 on: June 13, 2017, 05:00:41 PM »
I would suggest you tu "reset the Update Manager" by deleting the following registry key (using "regedit.exe"):
HKEY_CURRENT_USER\SOFTWARE\Itoo Software\Update Manager\Packages
Alternatively, use the attached .reg (open the zip and double click the .reg file). Reinstalling the plug-in is hilly recommendable too. Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
FC1888
« Reply #8 on: June 14, 2017, 05:05:07 AM »
Same just happened to me. Update Manager came up, saying update available "Railclone" version 3.0.0.
I thought it was weird, since the I have 3.0.4b.
However this is of course a beta version, so I thought, maybe this was the final version. So I updated.
I then opened Max, to check the version number, only to discover all the libraries were empty.
Good thing I found this thread and downloaded and double clicked the reg file and now everything is back to the way it was..
version 3.0.4b
Bit of a panic for a moment there, it would be great though, if you could figure out what went wrong, so it doesn't happen again
« Reply #9 on: June 14, 2017, 10:13:45 AM »
Our big apologies. There was a problem with that Update Manager package, but I can confirm, that's fixed. Thanks for all speedy feedback.
