Author Topic: Segment and clipping area into Array 2S problem  (Read 4364 times)
zules
« on: June 18, 2017, 04:38:05 PM »
I'm actually having trouble with an Array 2S.
I try to distribute pavels into a closed clipping spline but it doesnt work nicely. The spline are well draw and dont overlap each other, all corner angle.
Pavels are overlapping each other. I followed tutorial & this topic also : https://forum.itoosoft.com/index.php?topic=4585.0
The pb seems to come from the pivot of either segment or spline, I tried to align everything on the ground axe, Reset xform of all... cant figure it out.
Also, any tips & trick to add FPP grass into the pavel ? It's an extruded spline. Exclude object (the RC object) into the Area panel of FPP would do the job ?
Urgent work, so please help me :D
Thank you very much !
JG
Re: Segment and clipping area into Array 2S problem
« Reply #1 on: June 19, 2017, 03:21:14 PM »
Would you mind to send us your scene to have a look at it here? Thanks in advance.
