Author Topic: Gap between elements  (Read 4692 times)
patoaltaco
« on: August 07, 2017, 11:48:06 PM »
Im doing the 2.15 12 exercise of next steps with rail clone. The file is "chapter_2_brise soleil_start"
The exerccise is about Mat ID, but for practice porpouses i tried to make the style from scratch using the elements of the scene.
I almos got it, but i cant get ride of the gap between elements. It can be done mostly with padding but on the original style was not did using padding. I have compared every paramenter and i cant find what is it. I found that are the segments small and large brackets, but i dont know exactly what is it!
I attach my file.
Patricio.
Re: Gap between elements
« Reply #1 on: August 08, 2017, 11:10:16 AM »
Hi Patricio,
The X Fixed Size is set to a very small value, so when Display Unit Scale is set to meters it appears to be a 0,0m, but it's 0,1mm. Setting X Fixed Size of the "Large Bracket" to a similar value (like 0.1mm or 0.01mm) should do the trick. Hope that clears it up.
patoaltaco
« Reply #2 on: August 08, 2017, 06:08:04 PM »
Hi Michal!
That did the trick!
Patricio.
