Author Topic: Laubwerk tree /add a forest color map to increase variations in the leaves color  (Read 7133 times)
FO3538
I have tried this ->
But with no success. Only the red shows up, and no yellow or purple variations.
So I wonder if Forest color map works on Multi / sub object materials?
Yes, it's supported within the Multi/Sub-Object material. Please double check, you're modifying the correct material. As mentioned in this "V-Ray Material Override" post: "It is not safe to modify directly the "automaterial", because Forest keeps references to its source materials. Instead you should modify the material linked to item(s) - Custom Object(s) - Material(s). Any changes made this way, will be projected safely to the Forest's "automaterial"".
Hope that helps.
