Author Topic: Moving selected nodes while clicking Shift, clone them  (Read 26489 times)
« on: February 16, 2023, 12:22:06 pm »
Hi, welcome back!  8)
The segment node (orange) will be copied but remain in the same position as the original.
Regards
Re: Moving selected nodes while clicking Shift, clone them
« Reply #1 on: February 17, 2023, 10:02:54 am »
Hi, we cannot reproduce this. Segment nodes are displaced correctly.
Are you cloning a single Segment node, or is it part of the selection with other nodes ?
« Reply #2 on: February 17, 2023, 10:21:01 am »
Now I can see it is working fine with Max2022. Only Max2020 is a problem.
I`ll check .dlls for 2020, and clean up everything.
« Reply #3 on: February 17, 2023, 10:33:26 am »
Nope. I have cleaned up, reinstalled, and still have the same issue.
Even just adding a Segment node on the canvas has a small delay (about 1.5 seconds).
I think it is just my system and since this is the only happens with the Segment nodes I`ll pass it. It is not a critical issue.  ???
« Reply #4 on: February 17, 2023, 12:04:47 pm »
Interesting. I just tried with Max 2020 but cannot reproduce it either.
There is a tiny delay (tenths of a second) cloning Segment nodes, because it requires to modify parameters in the Max object, but not as your video.
In my case, i notice exactly the same delay in 2020 and 2023.
« Reply #5 on: February 17, 2023, 12:46:43 pm »
Here, I have a really noticeable difference. 2022 is a lot faster, same as yours.
I think something has to do with Windows itself probably. I noticed that Max2020 started up slowly after Widows Update a month or two ago.
But since this is not critical at all, I'll disregard it for now.
