Author Topic: 3ds Max 2009 64 bit & ColorEdge  (Read 36395 times)
blueroly
« on: May 28, 2009, 12:18:45 am »
Hi Guys,
I've installed the correct version of the ColorEdge plugin to "C:\Program Files (x86)\Autodesk\3ds Max 2009\plugins\" but cannot work out how to use it. From what I've read on here I select the material editor, click on 'get material' and ColorEdge should appear in the list. For me it doesn't appear :(
Can anyone point me in the right direction please...?
Regards
Blueroly
« Last Edit: May 28, 2009, 12:24:21 am by blueroly »
blueroly
Re: 3ds Max 2009 64 bit & ColorEdge
« Reply #1 on: May 28, 2009, 11:24:47 am »
FWIW I have the same problem using 3ds Max 8 at work... I've installed the correct version of the plugin but still nothing appears in the material browser.
What am I doing wrong...?
« Reply #2 on: May 28, 2009, 05:05:39 pm »
What renderer are you using ?
ColorEdge is not compatible with Mental Ray, so material browser hides it from list, except if "Incompatible" checkbox is enabled.
blueroly
« Reply #3 on: May 28, 2009, 06:58:51 pm »
Thanks, that worked although when I checked "incompatible" last night  I'm certain it wasn't there... anyway, it's working now :)
