Author Topic: Clone Lights ?  (Read 109929 times)
LsdyNicMS
Clone Lights ?
« on: April 08, 2011, 02:07:41 am »
Hi there,
I using your Clone tool every day and it's just amasing, thanks for creating that tool!
I was wondering if there was a way to use it on lights ?
I saw in another post that it could only work on meshes, but is that still the case ?
Is there another plugin from you gays that make that work ? RailClone may be ?
Stan
yuv
  • iToo Software - CEO
    • Itoo Software
Re: Clone Lights ?
« Reply #1 on: April 08, 2011, 02:16:43 am »
Clone only works with geometrical objects, there is not support for lights or other special objects. I don't know is there is some plugin that could make it in the same way that clone works. RailClone also has the same limitation.
Daniel Quintero
Itoo Software
www.itoosoft.com
daniel@itoosoft.com
LsdyNicMS
Re: Clone Lights ?
« Reply #2 on: June 26, 2013, 07:37:12 am »
Hey guys,
Is there any news about this,
is it still not possible to scatter lights?
It's really annoying to be able to scatter light geometry but have to place the lights (ie : ies lights) manually after, on top of the already scattered geometry...
Regards
Stan
Re: Clone Lights ?
« Reply #3 on: June 26, 2013, 09:32:08 am »
No, sorry. This feature is not available yet, but it is a priority in the RailClone wishlist.
AldingerWolf
Re: Clone Lights ?
« Reply #4 on: August 07, 2017, 09:46:58 am »
2017 any changes for light objects?
« Last Edit: August 07, 2017, 09:53:27 am by AldingerWolf »
Re: Clone Lights ?
« Reply #5 on: August 07, 2017, 12:12:03 pm »
I'm afraid not. We did some attempts, but could not resolve it efficiently.
Re: Clone Lights ?
« Reply #6 on: August 07, 2017, 12:24:38 pm »
General workflow in 2017 is using this script:
https://forum.itoosoft.com/index.php?topic=2929.msg15208#msg15208
full-blood
Re: Clone Lights ?
« Reply #7 on: November 02, 2018, 12:40:09 pm »
Posted by: iToo
« on: June 26, 2013, 09:32:08 AM » Insert Quote
I'm tying to find a solution to use lights with Railclone. Have you any solution to this problem ?
Re: Clone Lights ?
« Reply #8 on: November 02, 2018, 12:55:44 pm »
I would recommend ForestPack script mentioned above.
You can create ForestPack object from RailClone Object too if that is more suitable for You.
full-blood
Re: Clone Lights ?
« Reply #9 on: November 09, 2018, 02:55:26 pm »
Thank you. It's working but it's a pitty that there is no easier and faster way.
