Author Topic: Color Edge Corona render  (Read 50626 times)
CharlyRT
« on: June 25, 2025, 06:23:48 pm »
I noticed that Color Edge map doesnt work with Corona
at least not in v13
Im using 3ds Max 2026.1
it works ok with V-Ray
Re: Color Edge Corona render
« Reply #1 on: June 26, 2025, 09:59:09 am »
I've just run some quick tests with 3ds Max 2026, Corona 13, and ForestPack 9.2.4, and everything appears to be working correctly. Please feel free to send us any problematic scene - ideally a simplified version that reproduces the issue with minimal setup. Thank you in advance.
CharlyRT
« Reply #2 on: June 26, 2025, 05:41:27 pm »
mmmm maybe theres a confussion in the map, im not using Forest Edge, I mean the free plugin Color Edge
I forgot to attach the tests, so here there are.
PS. Theres no need to send a problematic scene it occurs even with the scene provided with the plugin and with any other, but Im attaching this simple scene that im using in the tests
« Last Edit: June 26, 2025, 05:45:46 pm by CharlyRT »
« Reply #3 on: June 27, 2025, 02:20:09 pm »
Apologies - I mistakenly referred to the Forest Edge map earlier. As you correctly noted, the ColorEdge map currently appears to be incompatible with the Corona renderer. I'll check it with our development team, but to be honest, I'm not sure whether this is something that can be implemented on our end, if it would require support from the Corona renderer team, or if it might need collaboration from both sides. That said, I should mention that we haven’t updated ColorEdge in quite some time, and unfortunately, we currently lack the resources to work on our free plug-ins. Thank you for your understanding.
