Author Topic: About nested styles  (Read 24122 times)
raffyraffy
About nested styles
« on: April 26, 2016, 11:07:51 am »
Hi everybody...
I am new in RailClone...
so, I was wondering if it's possible set up a style preset (previously saved) as "segment" for a new style setting...
in other words, it's possible to create a sort of nested styles?
Thanks in advance!
Ciao, Luigi.
Re: About nested styles
« Reply #1 on: April 26, 2016, 11:29:46 am »
Hi Luigi,
Thanks for contacting us,  we hope you enjoy using RailClone. It is indeed possible to nest styles.  All you need to do is select another RailClone object as the source for a segment.
If the nested object has randomisation you'll also find a "nested" checkbox in the segment's settings that ensures the randomisation cascades through the style.  (Note though that this disables instancing).
Finally,  if you plan to add a style like this to the library you should make sure that the nested style's size is set using the X and Y size parameters and not splines because these aren't imported by the library browser.  If you're not planning to add the style to the library you needn't worry about this limitation.
I hope that helps,  please let me know if you have any further questions.
Many thanks,
Paul.
raffyraffy
« Reply #2 on: April 26, 2016, 12:06:50 pm »
Thank you Paul, for quick reply  :)
It's possible only for the Pro version, ...I think.
Can you show me a simple preview of this feature?
Thanks again.
Luigi.
