Author Topic: Array Scale  (Read 26298 times)
DrunkenMaster
Array Scale
« on: November 16, 2018, 10:10:12 pm »
Hi, I have a problem. I want to scale element to clipping area in both directions X and Y. If i select mode as "Scale" in Rules section it scales element just by X direction, it still tilles in Y direction... Why ? I attached a file in the middle is original object, in the right scaled by X axes, in the left tiled by Y axes but I want to scale by Y too...
What i want to do, I want no tiling at all just scale default object by both axes to fill clipping area.
I should bee simple task, but I can't find away to do that...
is it Lite versions limitation ?
Please help !
Re: Array Scale
« Reply #1 on: November 19, 2018, 11:32:28 am »
RailClone can do that- no problem:
In any case, we cannot provide support in this forum. You should use an account with permissions to the Forest Pro forum.
Thanks for your understanding.
