Author Topic: Basic Parquet not working.  (Read 19888 times)
LM1206
« on: May 05, 2019, 02:16:29 am »
I'm following the parquet tutorial at https://www.itoosoft.com/tutorials/parquet-floor
I've attached the file.
This is not working as in the tutorial. Does the sequence component not work the same way anymore?
LM1206
Re: Basic Parquet not working.
« Reply #1 on: May 05, 2019, 02:49:57 am »
I've attached a file that gets a little further using translation and padding, but can't finish. That's two for two with this plugin trial
LM1206
« Reply #2 on: May 05, 2019, 02:58:38 am »
Scaling objects in the tutorial keeps them side by side flush to each other. Doing so in the plugin creates gaps....wtf? Again is this just an outdated tutorial =?
« Reply #3 on: May 06, 2019, 02:07:51 pm »
Hi. Tutorial is still fine. Sequence is working as expected.
You did not mark Increment on "Y" Mode . And Your segments are rotated in 90 degrees:
LM1206
« Reply #4 on: May 06, 2019, 05:02:30 pm »
thanks , kept hitting that button, but it never worked... didn't think to rotate the object along with this. Thanks again.
