Author Topic: Brick Building with Noise Modifier  (Read 19496 times)
johnlanius79
« on: August 17, 2018, 04:57:26 pm »
I am using railclone to generate bricks for a building.  If I add a noise modifier to the railclone itself...then my computer's memory gets maxed out at render time
if i add a noise modifier to the surface that the bricks are being generated on....the bricks no longer align.
Keep in mind this is a brick building...so it's vertical
Any thoughts?
Thanks.
Re: Brick Building with Noise Modifier
« Reply #1 on: August 18, 2018, 09:08:45 am »
Applying any modifier to the RailClone object will disable the instancing engine, and the object will be handle as a single (huge) mesh.
Unfortunately there is no way to avoid that, since is the way that the Max pipeline works.
If you want to add some variation to the bricks, i would suggest to randomize a bit the position of each segment, using a Transform node.
