Author Topic: Sloped plane  (Read 23417 times)
Fco3d
Sloped plane
« on: December 10, 2015, 06:06:09 pm »
Hello, I am working in this ceiling design, it supposed to be several wood slats different thickness, the problem is the ceiling is divided in big areas an they have different slopes, (like a stealth airplane) so I model the slats and assigned the same surface for clipping area and surface, the first time it worked fine, the grid follow the surface but now but when I try to copy to the next are the grid stay flat.
I try creating a new Rail clone from scratch, but still the same problem.
BTW I am using rail clone pro, but in my company IT does the purchase so I don't have access to rail clone pro forum :(
Thank you.
Re: Sloped plane
« Reply #1 on: December 10, 2015, 08:39:27 pm »
This should work, would you mind sending me a sample file of what you have so far and I'll take a look.
Many thanks!
Fco3d
Re: Sloped plane
« Reply #2 on: December 10, 2015, 11:01:34 pm »
Thanks for the answer, I managed to make it work, but it feel really clumpsy,
I have to create a polygon from top view then move the vertex on the Z axes to some random height, then apply my railclone setup, then adjust that polygon to the real size of the roof, now if I move the vertex too much, some parts of the raiclone grid drop to z=0 and the rest stay in place, so it look really weird.
I am attaching the final ceiling max file.
Thank you
Fco.
https://dl.dropboxusercontent.com/u/54203016/TepCeiling.zip
Re: Sloped plane
« Reply #3 on: December 11, 2015, 12:47:32 pm »
Distortion can often be caused when the clipping area and the surface boundaries are coincident. This is a know limitation that we're working on improving. In the meantime the solution is to use a clippling spline that's smaller than the surface - you can see more information about this and a handy script in the Extending Boundaries section at the bottom of this page.
Many thanks!
Fco3d
Re: Sloped plane
« Reply #4 on: December 12, 2015, 12:37:40 am »
I'll that a try.
Thank you for your help.
Fco.
