Author Topic: Can't get gradated color probability to work.  (Read 55499 times)
rohan256
« on: August 21, 2023, 01:20:50 pm »
I'm using railclone pro 5.3.0. Am trying to follow this tutorial - https://www.itoosoft.com/tutorials/graduated-colour-probabilities?back=duration%3D10%26page%3D2%26tag%3Drailclone
but it is not working. Have attached a screenshot showing what I've used. Where have I gone wrong?
Re: Can't get gradated color probability to work.
« Reply #1 on: August 21, 2023, 01:27:02 pm »
I'm sorry to hear you're facing these troubles. As mentioned in this "Parse error" tightly related post on our forum: "There's a new Expressions syntax since the RailClone 3. Expressions now require you to add a return property before the expression and a semi-colon (;)at the end of the line."
It should look like the following:
return <theCorrespondingExpression>;
in this case:
return if(Input1<YSplinePosition, 1, 2);
rohan256
« Reply #2 on: August 21, 2023, 01:37:09 pm »
Thank you very much. I knew I must have missed some simple point. Will keep this in mind when using expressions.
