Toggle navigation
Login
Register
RailClone
RailClone Lite
Transform causes uvw to stretch.
« previous
next »
Print
Pages: [
1
Author
Topic: Transform causes uvw to stretch. (Read 70323 times)
rohan256
Newbie
on:
September 02, 2023, 11:30:17 am »
Hi. If I use transform to scale any segment, its textures also gets scaled despite using realworld mapping. How can I retain texture scale even after scaling the segments?
Logged
ITOOSOFT
Hero Member
Re: Transform causes uvw to stretch.
Reply #1 on:
September 04, 2023, 07:15:38 am »
In some situations - like this one, you might find handy the possibility to map it directly within the RailClone plug-in by enabling the
Deform
Mapping
Apply Box Mapping
feature. Please feel free to check more detailed information about how to "
To Add Box Mapping to segments
" in our online reference guide.
Logged
rohan256
Newbie
Reply #2 on:
September 04, 2023, 03:12:48 pm »
I've have enabled box mapping for the segment in the deform tab. I think the problem is transform operator is scaling the segment along with the texture. There should be a uvw map operator that we can add at the end.
Right now I have put a uvw map modifier on top of the railclone object, but this is not a clean solution. Is there any other way to tackle this?
Logged
ITOOSOFT
Hero Member
Reply #3 on:
September 05, 2023, 09:02:32 am »
In such a case, please try disabling the
Display
Render
Use Instancing Engine
option to see if there’s any difference (might be, that’s just a partially supported feature in case of your render engine). I hope that helps.
Logged
rohan256
Newbie
Reply #4 on:
September 05, 2023, 12:16:53 pm »
Thanks! Disabling the instancing engine worked. I'm using VRay GPU which doesn't support it.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Lite
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
