Author Topic: Y count  (Read 71141 times)
anthonyhartleydenton
Y count
« on: February 21, 2024, 10:47:11 am »
hey All
for tile presets the plain tiles the Y count tops out at 20. can this be increased at all?
Re: Y count
« Reply #1 on: February 21, 2024, 10:58:47 am »
In our bundled presets, the Max. Limit for the Counter value(s) is set to 99999. Maybe you have overridden it? If so, you can easily adjust it in the corresponding Numeric Parameter node. I hope that helps.
Re: Y count
« Reply #2 on: February 21, 2024, 11:19:50 am »
thanks, Michael I'm making progress.   !
on the below image.  the final thing i need to do is get the 3 bands of decorative tiles to drop to the blue line - without another sequence appearing at the either the top of bottom.  any thoughts?
Re: Y count
« Reply #3 on: February 21, 2024, 11:27:05 am »
You can easily adapt the style as mentioned here. I hope that helps.
