Author Topic: Trouble with context menu in 3ds Max after instaling RClite  (Read 173738 times)
Envy900
« on: March 07, 2025, 11:51:11 am »
Hi, recentry after instaling RC Lite on my workstation I have a problem with context menu. After clicking RMB in this context I have notification about missing stuff from RC. The list is growing and now it blocked me an access to essetial options in context mentu. Could anybody help me out with this issue?
Re: Trouble with context menu in 3ds Max after instaling RClite
« Reply #1 on: March 07, 2025, 12:06:26 pm »
I would suggest resetting 3ds Max by deleting your user files. To temporarily remove the user profile:
  • Make sure that 3ds Max is not running.
  • Go to the following path: C:\Users\%username%\AppData\Local\Autodesk\3dsMax\your3dsMaxversion - 64bit\ENU
  • Rename the ENU folder to ENU_Old.
When 3ds Max is launched, a new ENU folder will be created. If the issue persists, you can restore the previous settings by deleting the new ENU folder and renaming the old one back to its original name.
I hope this helps.
Envy900
« Reply #2 on: March 07, 2025, 12:09:47 pm »
Is there any other possibility? This method will reset my set ups for viewports plugins etc.
« Reply #3 on: March 07, 2025, 12:12:14 pm »
You can try closing 3ds max and deleting all related 'iToo' & 'RailClone' .mcr files from this folder:
C:\Users<YourUsername>\AppData\Local\Autodesk\3dsMax\2024 - 64bit\ENU\usermacros.
Envy900
« Reply #4 on: March 07, 2025, 12:25:42 pm »
It didn't help. Max create all macros everytime i turn it on after deleting them.
« Last Edit: March 07, 2025, 12:30:18 pm by Envy900 »
« Reply #5 on: March 07, 2025, 12:36:48 pm »
In this case, please try temporarily removing the user profile. As mentioned earlier, you can restore the previous settings by deleting the new ENU folder and renaming the old one back to its original name.
Envy900
« Reply #6 on: March 07, 2025, 12:44:49 pm »
Okay. I will try it after my vacation. Since I'm finishing some work before leaving, I don't want any surprises right now. I will let you now. Thanks for your assist to this point
« Last Edit: March 07, 2025, 01:08:10 pm by Envy900 »
Envy900
« Reply #7 on: March 21, 2025, 07:10:24 am »
It helps for now. Thank you!
Envy900
« Reply #8 on: April 02, 2025, 07:53:17 pm »
This lines at menu start to generate again. Please help.
« Reply #9 on: April 04, 2025, 10:03:01 am »
I'm sorry to hear that the issue has reappeared. Have there been any recent changes to your 3ds Max configuration? Have you tried temporarily removing the user profile to see if that resolves the problem? Thanks in advance for any further feedback.
Envy900
« Reply #10 on: April 04, 2025, 06:34:17 pm »
Yes I did and helps to delete old notification. After reloading profile, problem start to accumulate again.
Envy900
« Reply #11 on: June 03, 2025, 07:46:55 pm »
Hey team, any help? I have to delete ENU folder again cuz i cant see all options after clickin RMB cuz your error pusz menu to the display border. Its annoying that you give me most easy and obvious advice and if this doesnt help, you dont answer
HELOO HELP GUYS!
« Reply #12 on: June 04, 2025, 09:26:29 am »
I'm sorry to hear you're still having trouble with this. Unfortunately, we haven’t been able to reproduce the issue on our end. If the problem persists, it may be best to remove the contextual menus to avoid further complications. To do that, you can delete the last few lines of the railclone_utils.ms file, which is located by default in the following folder:
C:\ProgramData\Autodesk\ApplicationPlugins\RailCloneLite202x\Contents\scripts\startup
if(maxVersion())[1] < 27000 do
RC_registerMenuItems()
end
Just to note: you should also remove the user profile afterwards. Deleting those lines won’t automatically remove the existing contextual menus - it only prevents them from being created again.
« Last Edit: June 04, 2025, 09:54:10 am by Michal Karmazín »
