Toggle navigation
Login
Register
RailClone
RailClone Lite
Install Problem
« previous
next »
Print
Pages: [
1
Author
Topic: Install Problem (Read 106297 times)
Kaelig
Newbie
Install Problem
on:
July 31, 2024, 08:45:53 am »
Hello everyone, i just got Railclone lite and finish the Installation but i have no idea to to use it in 3ds max, i have no Railclone icone on my Ui. Do i need more step after the Installation is done ? Thank you !
Logged
ITOOSOFT
Hero Member
Re: Install Problem
Reply #1 on:
July 31, 2024, 09:14:34 am »
Which 3ds max version are you using? There is no need for any additional steps - once installed, you should find it within the 3ds Max
Command Panel
under
Geometry
RailClone Lite
. Let me add that you might find our "
Getting Started with RailClone
" guide interesting and helpful.
Logged
Kaelig
Newbie
Re: Install Problem
Reply #2 on:
July 31, 2024, 10:04:56 am »
Hello, thank you for your anwser, i'm using 3ds max 2025, but no Railclone or Itoosoft doesn't appear anywhere on my command panel, i have 3ds max and Itoosoft on différent hard drive, maybe it cause problem ?
Logged
ITOOSOFT
Hero Member
Re: Install Problem
Reply #3 on:
July 31, 2024, 10:09:48 am »
3ds Max 2025 is currently supported in the beta version of RailClone, which can be downloaded from the User Panel under the Downloads - Beta versions section. If you do not have a Pro license, you'll need to wait until the final versions are released, along with the Lite versions. Thank you for your understanding.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Lite
Install Problem
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
