Author Topic: Why only 10 copies????  (Read 81768 times)
Mnietek
« on: February 26, 2024, 12:17:10 pm »
Really simple setup - three segments (boxes with different width) and one spline.
Why there is only 10 copies? Is this limitation of Lite versions?
I cant find any info about such limitation...
max file attached
Re: Why only 10 copies????
« Reply #1 on: February 26, 2024, 12:27:40 pm »
When using empty Segments (a standard Segment node without having any object assigned), it's important if these have a defined size (under General - Object - Fixed Size / by the Transform Operator / by exporting Fixed Size parameters) or not. By having zero dimensions, it's used to "break" the array.
I hope that clears it up.
Mnietek
« Reply #2 on: February 26, 2024, 12:36:03 pm »
Thanks. I realized that segment number 3 has no object assigned.
After assigning the object, everything is OK...
