Author Topic: Decorative tiles running to corner  (Read 101261 times)
anthonyhartleydenton
« on: March 05, 2024, 01:56:23 pm »
Hi there
how would i get the decorative hanging tiles to run to the corner please?
thanks T
Re: Decorative tiles running to corner
« Reply #1 on: March 05, 2024, 02:27:16 pm »
Well, you can disable the Left & Right Verge parameters, but that would require "shifting" every other row (for example, by using the Transform Operator). Alternatively, you can prepare a "one & half-sized decorative segment" and use that instead. I hope that helps.
« Reply #2 on: March 05, 2024, 02:40:29 pm »
The attached is my flow.  would you be able to elaborate on how I would tacle with first options you suggest please?
« Reply #3 on: March 06, 2024, 09:08:20 am »
Please find attached a sample scene showing the possible style setup. It uses Sequence Operators to handle Left & Right Verge segments in a similar way as in the case of the Tiles Input of such a Roof Macro. I hope that helps.
