Author Topic: Ramp of viaduct or bridge?  (Read 50142 times)
markc0826
« on: June 18, 2013, 07:38:50 pm »
Can I build ramp of viaduct with RailClone?
Re: Ramp of viaduct or bridge?
« Reply #1 on: June 18, 2013, 08:02:46 pm »
Yes, using a sloped spline. Although in the current version is not possible to adjust the height of the columns dinamically. As workaround, you can make them enough long to go across the terrain, so the extra geometry is hidden at render.
markc0826
« Reply #2 on: June 19, 2013, 09:10:46 am »
I use Helix to build, but it seems on the Plane??
such as the image...
« Reply #3 on: June 19, 2013, 09:39:22 am »
This is a limitation of the Lite version, it works only with flat splines:
http://www.itoosoft.com/railclone/litepro.php
Sorry by not commenting this before, i just realized you was posting from the Lite forum.
markc0826
« Reply #4 on: June 19, 2013, 04:53:14 pm »
You mean it will work correctly on the PRO version?
« Reply #5 on: June 19, 2013, 05:02:30 pm »
Yes. In fact, the plugin includes specific options for Z deform: http://www.itoosoft.com/railclone/reference/refsegments.php#deform
