Author Topic: v1.4.2 - segments not using "Bend" are NOT aligned correctly following the path  (Read 53299 times)
harumscarum
  • Guest
hello
i was happy to see in 1.4.2 changelog The segments not using "Bend" are aligned correctly following the path, but still same issue - please see attached image
The fix modifies the alignment of segments, previously we used the tangent on the path, and now the vector from the current position to the next point. This behaviour is more convenient for some types of fences.
In this case, it seems a different issue. Please, post your scene to see the parameters. Probably it may be fixed changing some values.
In the attached scene, i use Evenly and Corner rules and the result is correct.
